Old 11-25-2009, 01:36 PM   #1
BobUnkefer
BobUnkefer's Avatar
Default Should be easy ? to get answer to
I would think there are numerous out there that know this,,,,,,
What is the weight difference between a small block/glide and a big block/turbo?
Think 68 Camaro application here.
100#?
125#?
more?
less?
Thanks,
Unk
BobUnkefer is offline   Reply With Quote
Old 11-25-2009, 01:52 PM   #2
Tim H
Tim H's Avatar
Liked 482 Times in 159 Posts
Default Re: Should be easy ? to get answer to
Will the Rat be wearing alum heads ?
Old 11-25-2009, 01:58 PM   #3
BobUnkefer
BobUnkefer's Avatar
Steel headed Rat
Old 11-25-2009, 02:24 PM   #4
FED 387
Liked 333 Times in 180 Posts
Red face Re: Should be easy ? to get answer to
Bob----
Approx weights in Pounds
Engines:
steel head/intake SBC --575
steel head/intake BBC-- 685
Transmissions:
PG--95
Turbo 350--125
Turbo 400--195
TRANS WEIGHTS LESS CONVERTOR & FLUIDS-- ADD APPROX 25-30 LBS FOR CONV.--ADD 2 POUNDS PER QT TRANS FLUID
these are just ball park figures a lot depends on if you have trick or lightened parts in trans --small convertor(7/8in)---deep or stock pans---shorty or regular length tail case etc. Hope this helps -Comp 387
Old 11-25-2009, 02:27 PM   #5
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Approx. 226 lbs difference between a 396/325 HP 1968 Camaro with a 400 turbo and a 1968 350 Camaro with a P/G. The weight difference would of course be less if you ran a 350 Turbo or a 200 metric behind the 396.
Old 11-25-2009, 02:27 PM   #6
Tim H
Tim H's Avatar
That TH400 weight of 195lbs seems high?
I believe there to be approx. 30 lbs difference between the glide @ 95 lbs and the Th400 @ 125 lbs.
Old 11-25-2009, 02:36 PM   #7
BobUnkefer
BobUnkefer's Avatar
I knew you all would have the answer, now another question, how much weight is saved with a metric over a turbo?
I know, just full of questions,,,,,
but the answers are appreciated
Unk
Old 11-25-2009, 02:37 PM   #8
X-TECH MAN
Banned
Talking Re: Should be easy ? to get answer to
Unk
Not sure but your wallet would be lighter because the metric wont last very long behind the big block.
Old 11-25-2009, 02:56 PM   #9
FED 387
Metric 200 trans weighs about 35 pounds less than a Turbo 350 trans---another thing to consider is it takes about 45 HP/400---30 HP/350---20HP/PG -powerloss going thru the transmission to the drive shaft---If $$$ is not a concern and you want a BALLS OUT racing trans talk to Scott McClay---if you are going STOCK/SUPER STOCK racing talk to Billy Lynn he builds lots of them his prices are fairly (he-he) reasonable--If you ever saw the inside of a "stock" 200 trans you would wonder how the hell they ever hold up in normal street use---- weight/ HP is the limiting factor on a 200---350 will take quite a bit of HP/Torque compared to the 200---call around talk to the trans guys they won't bull**it you--- Comp 387
Old 11-25-2009, 05:10 PM   #10
bill dedman
Liked 6 Times in 4 Posts
FED 387 sed:
"about 45 HP/400---30 HP/350---20HP/PG"
But, how much for the metric-200, and just for the sake of comparison, how much for a 904 T-Flite?
Any information will be appreciated!
Bill
bill dedman is offline   Reply With Quote
