Old 11-22-2009, 04:21 PM   #1
art leong
Default Compression ratio calculators??
I've used a few different sites that come up with 3 different numbers.
Specs are 3.484 bore, 3.976 stroke, 10.2 cc dome, deck height 0, gasket thickness .074
gasket bore 3.51. Cylinder head volume 48 cc's
The sites I've found vary by as much as 2 full points (13 to 1 up to 15 to 1) Using the same input data (some of the sites don't ask gasket bore size) I would think it shoulkd be within half a point.
Art Leong 2095 SS
Old 11-22-2009, 06:07 PM   #2
Adger Smith
Liked 880 Times in 311 Posts
Default Re: Compression ratio calculators??
You have a PM
You have more than enough
Adger Smith (Former SS)
Old 11-22-2009, 06:08 PM   #3
jmcarter
jmcarter's Avatar
Liked 3,205 Times in 977 Posts
Art, did you try Wallace Racing calc?
http://www.wallaceracing.com/cr_test2.php
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 11-22-2009, 08:39 PM   #4
Jeff Lee
Jeff Lee's Avatar
I find this site is real simple for numerous race calculations:
http://users.erols.com/srweiss/index.html
Jeff Lee 7494 D/S '70 AMX
Old 11-22-2009, 10:26 PM   #5
art leong
What gets me is I get 15.70 on one site 14.62, 16.30 on another
This is with putting the same numbers in Some take in to account the head gasket bore others don't. But it shouldn't come to 2 full points. I think there is a formula in an old rule book I can do on paper.
Art Leong 2095 SS
Old 11-22-2009, 10:44 PM   #6
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
Talking Re: Compression ratio calculators??
Artie,make sure you bolt that hood down good and tight.............................................
Former NHRA #1945
Former IHRA #1945
T/SA
Old 11-22-2009, 11:00 PM   #7
art leong
Ed I have my front mounted parachute on that hood
Art Leong 2095 SS
Old 11-22-2009, 11:23 PM   #8
Adger Smith
Art,
I think there is a formula in both the How to Build Books. Both Small Block and Big Block. I have it on my shop computer and will PM it to you tomorrow. It will come out with in a .00 of what I sent you.
Adger
Old 11-22-2009, 11:36 PM   #9
NORMAN BARNARD
Liked 2 Times in 2 Posts
Useing your info. Above i got 13.540:1, normally aspirated at sea level........this is an older computer program i use with sprint car
motors.
NORMAN BARNARD is offline   Reply With Quote
Old 11-23-2009, 09:05 AM   #10
art leong
I'm going to run the motor the way it is. But I was perplexed at the variation in the different programs. I wonder if the calibations are done by nhra in different divisions LOL.
Art Leong 2095 SS
