Old 11-15-2009, 05:13 PM   #1
chevy2
chevy2's Avatar
Liked 52 Times in 5 Posts
Default 69 Camaro and race parts for sale
Cleaning out the garage for the winter project. . . . . Items for sale listed below:
1969 Camaro, all steel except hood, clean body, set up for 10.5 tire, will hold bigger. All windows are glass, no lexan, original dash, column, and headliner, chrome moly chassis from firewall back, tied into original front subframe, has original floor up to rear of trans tunnel, Kirkey aluminum seats, Strange slotted rotor brakes front and rear, Strange gun drilled 40 spline axles, 4.30 pro gears, Strange aluminum 3rd member w/ heavy duty pro mod style pinion support, Koni coil overs in rear, 4 link w/ torsion bar set up, QA1 adjustable shocks in front w/ tubular control arms, new bumpers, quarter skins, all body work done on front end, doors, and decklid, parts are in black sealer, nice car, clear texas title . . . . . . . . SOLD
MSD 7AL2 ignition box w/ pro power coil . . . . [COLOR="rgb(46, 139, 87)"]SOLD[/COLOR]
MSD 6AL ignition box w/ blaster coil . . . . . SOLD
MSD distributor . . . . . . . SOLD
Lemons stepped headers for short deck BBC, 67-69 camaro w/ rack and pinion, new, 2-1/4 stepped to 2-3/8 w/ 4 inch collector, never been on an engine. . . . . SOLD
Aluminum oil pan for chevy II, rear sump, possible early Hamburger, never been on an engine. . . . . . . $125
Cragar supertricks, very clean 15 x 3 multi lug pattern, original satin finish, 15 x 12 new old stock rears w/ multi lug pattern, never had a tire mounted on them . . . . SOLD
355 bracket motor, World products angle plug heads, 010 block, Victor Jr. intake, Holley 800 carb, Moroso electric water pump, Fluidampr balancer, Moroso Chevy II pan, small roller cam, roller rockers w/ stud girdle . . . . . . . SOLD
Turbo 350 trans w/ 5000 stall converter, trans brake, B&M ratchet shifter, less than 10 passes since freshened. . . . . . . . SOLD
You can reach me @ (210)710-7870 if you have any questions, or send me an email, jrodjr1975@hotmail.com, or send PM . . . . . thanks for looking! Prices are negotiable, I'm easy to work with.
JR
Last edited by chevy2; 12-07-2009 at 12:09 AM. Reason: SOLD items, revised pricing
chevy2 is offline   Reply With Quote
