Old 11-14-2009, 09:44 AM   #1
TMaggio
Default 1992 Camaro RS Quay Superstocker
-- 1992 Camaro RS Ed Quay SuperStocker --
- Currently set up T/K as SS/CS
- Have matching hood/hardware and headers for GT class
- Chromemoly Ed Quay 4-Link Chassis – rotisserie prepped gun-metal grey undercarraige
- Approximately 150 total runs on chassis
- Braced Ford 9", MW Center Section, Strange 35 Spline, 6.50 Ratio
- Aluminum Driveshaft
- Lamb Brakes - Dual Calipers / new pads
- Weld Wheels - AlumaStars
- Adjustable Koni Struts - Re-Valved by Lamb with limiters
- Adjustable Afco Rear Coil-Overs
- Computech Data Logger with EGT
- Shiftnoid - B&M Electric Shifter
- AutoMeter Gauges / Lamb Brake pressure gauge
- Built-in outlets for oil pan and transmission pan heaters
- Flaming River Shut-off switch
- 2750 # wet w/o driver
- Over 200# of removable ballast
301 cu in SBC-(Patterson/Davinci/Jesel/Stefs/Fluidamper/MSD/Crank Trigger)
- 10 runs since freshened (pistons/rings/GRProds/bearings/gaskets)
- Best run in ss/cs - 9.75 at 139 mph w/o Radials,VacPump
Coan Powerglide - 2.08 gear set
7" Coan Converter
Multi Class and Divisional Wins
Price Reduced – $29,500 T/K !!
Some photos can be seen on autoimagery.com under Tim Maggio.
If interested please contact Tim for additional photos and/or questions.
315-524-0025
kmaggio1@rochester.rr.com
TMaggio is offline   Reply With Quote
