Old 11-11-2009, 10:53 PM   #1
pro stock chuck
pro stock chuck's Avatar
Liked 53 Times in 17 Posts
Default Fresh 350 sbc 255/280 hp short block
Fresh 350 (never fired) RAN 1.03 under venolia piston greg luneack ring package you can choose
the cam. Engine spec. 010 casting block 30 over, 3.493 stock crank 442 casting, chev b rods bore and bushed with arp bolts,cloyes timing chain, ati damper,timing cover and oil pan. $3900. Southern calif. (p.s. No lifters) CHUCK ECHMALIAN
pro stock chuck is offline   Reply With Quote
