Old 11-11-2009, 06:16 PM   #1
Michael Galofaro
Default Motor, trans and conv
Reher morrison 555, Trans specialties pro line 5000 and A-1 8" conv.
Motor has 8 dyno pulls - 1 full pass and 1 1/8 mile pass
Trans is all new (drum-clutches-band etc) and fresh cert
Motor specs:
Everything from reher morrsion except the following upgrades - bowtie billet capped block, jesel rockers and belt, kinlser fuel injection, moroso pan, vacuum pump.
Made 928 hp at 6500 - should be around 970-980 or so at 74-7500(ran out of time to make more pulls) .Ran 4.78 @ 144.xx in 2040 lb dragster on the 1/8 pass.
Also have manifold and carb for either alky or gas if desired.
Will sell everything for 16,500. Or I will take injection off and sell it for 15,000.
Have MANY other parts as well :
2 sets dart 320 cnc heads - 1 cut for jesel - 1 not
Dale cubic 1150 carbs
JE 4.600 pistons (2 sets- used but all good)
ati damper 7" ext bal - brand new
fluidamper 8" ext bal - brand new
1.66 shorty gear set
moroso 3 quart accusump
chuck nyyten 1050
holley 950 cfm alky carb
stroud cam lock belts - out of cert
simpson cam loc belts - out of cert
Auburn posi unit - brand new
richmond 4.11 gears - brand new (street gear)
callies 4.75 crank
K&R in-line throttle stop - new
MSD HVC-2 coil - new
East coast electric ultra mini alt
Also 427 short block
Will look at trades for Beadlocks - must be 16*16 4"bs
Carbon Fiber Nitrous bottles
maybe anything interesting
Michael Galofaro is offline   Reply With Quote
