Old 11-03-2009, 08:10 AM   #1
Jim Woods
Liked 12 Times in 7 Posts
Default need Ford help
Looking for a timing tab for a 428 cj. This is the tab that mounts with 2 small screws .any help appreciated
Jim Woods
Jim Woods is offline   Reply With Quote
Old 11-03-2009, 09:47 AM   #2
FED 387
Liked 333 Times in 180 Posts
Exclamation Re: need Ford help
Jim-----look on Ebay item 370282330338---- $8.50 plus $2.50 shipping--- ---Good luck---Comp 387
Old 11-03-2009, 12:44 PM   #3
Rory McNeil
Default Re: need Ford help
Jim, Ford used a couple of different timing pointers for the FE engines during the 60`s. From late 63 thru 67, the tab was attatched to the aluminum timing cover with 2 small screws of the same size (5/16"?). Starting with the 68 model year, thru the end of FE production in 76, the timing tab used 1 small screw on the inner hole, and the other hole was much larger, as one of the timing cover bolts went thru the tabs and timing cover, & into the block. The 68 and later FE`s also had much thicker harmonic balancers. It sounds like you have the earlier cover, which will work fine, but is not the correct unit for a 428 CJ, as they were made only for the 68 -70 model years. If this engine is for a stock restoration it could be a concern, otherwise it will work OK. That tab on Ebay is for the 68-76 timing cover by the way. The 428 CJ tab is no different than a 360, 390, 410, or regular 428 engine, although the 428 SCJ (LeMans capscrew connecting rods) balancer is a bit larger, so the pointer is a bit different.
NHRA 6390 STK
M/S 85 Mustang
Old 11-03-2009, 01:06 PM   #4
Jim Woods
Thanks guys, I appreciate the help.I knew this was the place to get the info
Jim Woods
