Old 10-31-2009, 12:01 PM   #1
honkycat
Default Oil Pan & Bellhousing SB Mopar
Wanted Trick Ti 7-5/8 bellhousing for SB Mopar Also Machined Dry Sump Oil Pan for Alum Block This is the one that mounts the pump on the oil pan , need a pump also . If you have either or know someone who does Call 479-783-8176 evenings .....Thanks
honkycat is offline   Reply With Quote
Old 11-02-2009, 10:11 PM   #2
Jeff Teuton
Liked 325 Times in 50 Posts
Default Re: Oil Pan & Bellhousing SB Mopar
I have a new Browell can for a S/B Mopar if that might help. Jeff Teuton jefft@southlanddodge.com
Jeff Teuton 4022 STK
