Old 10-27-2009, 12:18 PM   #1
FED 387
Liked 333 Times in 180 Posts
Question pro tree trans brake Aluminum valve body ????
Have a Hipster ALUMINUM pro tree trans brake valve body---Can I make this into a regular trans brake without too much difficulty or is it too much trouble??? Will it work???? Can it be done??? Comp387
Old 10-27-2009, 07:34 PM   #2
Bryan Gillespie
Banned
Default Re: pro tree trans brake Aluminum valve body ????
Throw it the trash, the alum. trans brk. are very wide spread on RT's
Bryan Gillespie is offline   Reply With Quote
Old 12-05-2009, 09:40 PM   #3
R&S Motorsports
Yep I found that out the hard way go back to a cast iron pro brake!!!!
R&S Motorsports is offline   Reply With Quote
Old 12-05-2009, 10:09 PM   #4
FED 387
Cool Re: pro tree trans brake Aluminum valve body ????
forgot about that thread!!!! anyway we tried it out in back to back testing(alum vs iron) same day for both transmissions/valve bodies and it (alum) was very erratic compared to the iron body put them (alum vs iron) in 2 different transmissions(identical in every way possible) and it (alum) still was screwy---so we pawned the alum one off on a guy that thought he "just had to have it" for 2 cases of trans fluid and some pan gaskets---Comp 387
