New 2010 Continental Cargo by Forest River.
Loaded 30' Automaster w/ the following options: 54" extended tongue Frame & Wire for roof a/c 60" double side door 12 Volt battery in recessed in floor in cabinet 12" extra height Insulated Generator box w/ 36 x 33 gen door Wider Ramp door w/ 36" flap Screwless exterior LED Exterior light package AM/FM/CD Stereo w/ 4 speakers Recessed dome lights: 4 in ceiling, 4 near floor for tying down car & 2 over workbench 36" High Carpet on walls Electirc tongue jack 12 Volt Warn winch mounted in cabinets Super Stock Package includes: .040 Exterior Metal (Red, White, or Black), Taped Exterior Metal Panels (with screwed seams), Rubber Floor Covering Front 8' w/ATP Rear and on Ramp, Double 24" RV Doors with Piano Hinges and Flush Lock, L-Shaped Base Cabinet with Overhead and Wardrobe, Glued Interior Aluminum Wall Panels, Freezer-Type Ramp Door Latches, Race Mate (4) Piece Accessory Pack, (4) 5,000lb D-Ring Tie-Downs, (2) Non-Powered Roof Vents, (5) 4' Fluorescent Lights with (1) Wall Switch, (2) 500-Watt Recessed Quartz Lights with (1) Wall Switch, (2) Interior Wall Recepts Exterior Wall Recept with GFI, 30-Amp Breaker Panel with Lifeline and Cable Hatch, Aluminum Wheels, Bright-Dip Aluminum Front Corners, Bright-Dip Aluminum Rear Structure, 6" of Bright-Dip Aluminum along the bottom of both sides! Normally $17,900.00 Sale Price $15,900.00!!! Financing Available with approved credit through Sheffield Financial. Mike Gardner Hillwood Sales 800 754 4202 703 675 4479 cell |
