Old 10-14-2009, 12:15 PM   #1
mopar jeff
mopar jeff's Avatar
Default 1994 Mustang Cobra SVT racecar for sale "Price Reduced"
-1994 Ford Mustang Cobra SVT
-Coast High Pro Street 410ci stroker kit; Includes:
- 4340 Crank, H-beam rods, Chromemoly rings, Clevit 77 bearings
-Main Girdle, fly cut pistons for high lift cam.
-Coast High Pro Mustang Oil Pan.
-Bennet Racing Custom Cut Solid Roller Cam .
-Dyna Gear Timing Gear set.
-Trick flow twisted R stage 2 ported heads from total engine airflow with crower titanium locks, and keepers, upgraded springs, probe valve girdles.
-Comp cams like solid lifters.
-Comp cam chromemoly roller rocker arms.
-Ford Motor Sports Tall valve covers.
-Kooks Custom Headers 1 7/8" w/3.5" outlet.
-MSD 6al ignition box and MSD 8584 distributor, plug wires and HVC coil.
-Edelbrock Super Victor intake manifold.
-Holley HP 1000 carb worked by Biggsk, flows 1000 cfm.
-CSI throttle bracket with Lokar cable
-Summit 15 Gallon aluminum fuel cell w/sending unit.
-Holley red Electrip Pump and Aeromotive fuel pressure regulator with -10 filter.
-Aeroquip -10 and -8 steel braided hose, Y block and fittings for the fuel system.
-ARP Engine bolt kit.
-Fluid Dyne radiator.
-Power Stop cross-drilled rear rotors.
-Ground Pounder Upper and lower control arms.
-Auburn Posi locker w/motive 4.10 gears and Ground Pounder girdle.
-Tokico fully adjustable illumina shocks and struts.
-Adjustable caster/camber plates.
-Eibach rear springs.
-Autometer 5” tach.
-Autometer water temperature and oil pressure gauge.
-ARP Head Stud kit.
-Summit High Torque Starter.
-tublar k-member and arms
-brand new Weld pro star wheels
-10 point cage with Kirkey aluminum seat
-brand new RCI belts and trans blanket to pass tech inspection.
-brand new c4 trans with TCI trans brake and reverse manual valve body
-sub frame connectors
-brand new red paint with pearl flakes and white racing stripes
-set to run 10.90s or faster
-Steal it at $9,999.95 or make a reasonable offer.
-There is more in the motor than the asking price for the whole car.
-Must sell soon to fund my stocker project.
-Email for photos and with offers to inlandjandl@msn.com
-Call Jeff at (951)743-9759 !!!!! FREE Local Delivery !!!!!! near Riverside, CA
mopar jeff is offline   Reply With Quote
