Old 10-14-2009, 11:32 AM   #1
Philip Saran
Liked 14 Times in 11 Posts
Default Battery Box Mounting?
I got my shiny new TAYLOR battery box yesterday and am wondering
about the mounting of it. Read through the NHRA rule book and only
find a reference to 1/2" bolts (2) for a weight box bolted through the
floor/frame rail. Same for a battery box or just the two threaded rods
through the box and trunk floor?
Phil Saran
Parker, Colorado
Philip Saran is offline   Reply With Quote
Old 10-14-2009, 03:51 PM   #2
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Default Re: Battery Box Mounting?
The box and battery should both be bolted THRU the frame rail , or a suitable crossmember. The box with at least two 1/2" bolts and the battery hold down with 3/8" or larger. .....The sheetmetal of the floor wont hold up against the mass of the weight box or battery in the event of a crash. ...........Tom
Old 10-14-2009, 04:55 PM   #3
Philip Saran
Tom,
Thank you, then I can mount the battery box the same way I did the weight
box in my old stocker, with 2 1/2" bolts through the trunk floor and the frame
rail on the right side.
Man makes plans, God laughs.
Phil Saran
Parker, Colorado
Old 10-14-2009, 05:49 PM   #4
Greg Reimer 7376
Liked 719 Times in 220 Posts
Originally Posted by Philip Saran View Post
Tom,
Depends on the plans.
Old 10-15-2009, 12:26 AM   #5
Ken Haase
You're getting close....
" Man proposes, God disposes"--- U.S.Grant
Ken Haase is offline   Reply With Quote
