Liked 196 Times in 29 Posts
C/ED National Record Holder – Will Sell Whole or Split it Up.
We will sell complete $57,000.00 (no spares with this price, spares could be negotiated) OR Roller Car complete ready for your engine and transmission with Race-Pak computer, fuel pump, MSD digital ignition, MSD coil, CSR remote water pump with holding tank, Strange 9” rear, Lamb Carbon Fiber brakes, Stroud chutes and belts, Carbon Fiber Dash and seat w/cushion, Precision three speed shifter with air bottle (controlled by MSD ignition), BG fuel pump, remote oil filter, Weld rear wheels and Goodyear tires. This car has run 1 flat sixty foots. $25,000.00 Two shorty Pro-Flites - $5,000.00 each Extra Strange 9” 5.50 chunk $700.00 3 Coan negative convertors $1000.00 each 750 CFM Carbs (Book, BLP, Steve Taylor) $750.00 each CFE sheet metal intake to match above heads $950.00 Weld Wheels 12” – 4-1/2 bolt center w/Goodyear 12x33 Tires $500.00 Spitzer Carbon Fiber Scoop $350.00 Three Kenwood racing radios with two crew headsets $500.00 Engine is a 292 CID Short Deck Aurora Block with 10 degree CFE heads, Del West hollow stem titanium intake valves, Xceldyne hollow stem exhaust valves, PAC springs, Jesel Mohawk Rockers, Jesel push rods, Jesel lifters, BME pistons by Patterson, Total Seal Diamond Finish Rings, Titanium-Cassidium coated wrist pins, GRP rods, Single stage external oil pump, Charlie’s Oil Pan, Star vacuum pump, HRE Intake, ATI balancer, MSD crank trigger.. This engine has 15 runs on it since freshened (pistons, rings, bearings). $26,000.00 Contact Gary Merrick 330-219-4738 or Charlie Gilbertson 330-714-9075 Reference Racing Junk Ad #1681691 for pictures |
