Old 09-25-2009, 04:33 PM   #1
Alex Denysenko
Alex Denysenko's Avatar
Liked 4 Times in 3 Posts
Default Really really BIg Garage Sale
Stuff that we are tired of tripping over or moving.
Chebbie stuff:
1 1969 350 300 HP low mileage short block never apart.
Pan removed to see if it was a 4 bolt block
Large balancer to flex plate. Numbers on request make offer
1 1976 1 ton truck 350 4 bolt main bare block standard bore make offer
2 15 x 8 chrome (rough but straight) Astro style slotted steel wheels $50 for the pair
2 New Mr. Gasket solid motor mounts #3672 $25
3 New Mr. Gasket SBC #150A header gaskets $5 per set
1 NOS new in the box 3958602 SBC cylinder head make offer
3 used SBC complete head #462624 make offer or free to needy chebbie home
18 inch Permacool stainless steel 6 blade flex fan NEW $30
17 inch Flexalite #1027 Red Flex Fan NEW $40
Hooker 11230 3" x 18" 3 bolt collector extensions with new gaskets used one run $50
2 inch 4150 Holley pattern 4 hole plastic or phonelic resin carb spacer NEW $25
TFS 23006 Billet Aluminum cannister fuel filter NEW $60
Ford stuff:
1984-85 E4ZE-GA OEM 302 HO aluminum 4 barrel intake manifold mint! $150
1966-67 C6OE-B OEM 289 4 barrel cast iron intake manifold very nice $150
1968 C8ZE-A OEM one year only "J" code 302 4 barrel cast iron intake manifold $200
1972-73 351C 4V D1ZE-BB OEM spread bore intake manifold like new $200
1972 and up Motorcraft 4350 series 4 barrel carb rebuilt very nice $150
1968 302-230 Merc NHRA legal for S/SS 4150 Holley carb by Brashears baddest on the planet.
INQURE
289-302 near new mint front sump oil pan $25
289-302 brand new NOS FoMoCo/FRPP front sump oil pan $40
302 5.0 used rear sump oil pan nice $25
2 sets Manley 1.580 used 50 runs Nex Tek valve springs #221443-16 $50 a set
3 sets Manley 1.610 used 50 runs Nex Tek valve springs #221444-16 $50 a set
Manley/Erson 221444-16 (same spring) NEW in the box valve springs 1.610 $350 a set
Lunati 1.550 #73021 killer springs NEW in the box valve springs $100 a set
Comp 985-16 1.430 NEW in the box valve springs $80
Comp 733-16 Titanium 1.625 retainers NEW $250
Comp 4702-16 1.640 spring cups NEW $30
Comp 50mm 289-351W SS billet roller cam used contact for specs $200
Comp 55mm 289-351W SS billet roller cam used contact for specs $200
Comp 8931-16 SBF 289-351W or 351-400C tie bar hydraulic roller lifters NEW in the box
$475
Lunati 71900 "G" series hard face hydraulic Ford lifters NEW discontinued 5 years ago.
Fits all FoMoCo except FE Perfect for Sherman conversion $90
Crane SBF Pro Series 44542-16 roller lifters NEW NLA $525
18 R847 Speed Pro 289-302-351W 1.6 ratio steel rail rocker kits NEW $100
16 R879 Speed Pro 5.0 302 1.6 ratio pedestal mount rocker kits NEW $160
289-302 1.6 ratio Crane 36800-16 heat treated steel rocker kit NEW (impossible to find) $150
Innovators West #204 28 oz SFI 6.5 inch 4 bolt harmonic balancer NEW $300
M-6010-BOSS302 Ford Racing 4 bolt block (NHRA legal) NEW in the box and on the skid $1490
79-2004 Fox body and Mustang Metco very high end adjustable upper control arms NEW in the box $260
Fox Mustang HD clutch fork M-7515-A NEW $20
McLeod #16934 Super Duty steel SBF clutch fork NEW $75
17 inch reverse rotation stainless steel 7 blade flex fan nice USED $25
TCI SFI C-6 trans shield kit NEW $100
C-4 cast aluminum case fill deep trans pan NEW $85
289-351W Billet fabbed custom valve covers USED $200
289-351W Comp/Hartman light weight plastic medium tall valve covers with hardware NEW in box $50
289-351W chrome cheap chinese tall valve covers with breathers NEW $25
Richmond 6.20 lightened 9 inch Ford Pro Gear ring & pinion like new $200
Ford 8.8 chrome differential cover NEW $20
1993-98 Lincoln Mark VIII OEM honey comb aluminum 16 inch wheels used $125 all 4
Sony CDX-454RF ten disc CD changer brand new in the box never opened $150
BMW:
4 14 spoke OEM BMW 18 inch wheels with like new P245 50R 18 Dunlap 100H MS Wintersport M3 directional tires mounted on them pics on request Make offer
This stuff all needs to go.
Plus net shipping cost or available for pick up
Might be able to bring some of it to Indy Fall Classic or Rockingham Finals
Contact me vial e-mail at
monymkrssla@aol.com anytime
or call 219-861-1214 days
Thanks
Alex
Alex Denysenko NHRA 3038 SS, 3305 STK - IHRA 6 SS, 330A STK
Moneymaker Racing LaPorte Indiana 219-861-1214
www.moneymakerracing.net
Alex Denysenko is offline   Reply With Quote
