Old 09-24-2009, 08:36 AM   #1
BIZMANRACING
BIZMANRACING's Avatar
Default Retarding dist.
i've got a problem and its happened to be twice in back to back trips to the track.
i've been testing my car i guess in get ready for next year before i box it up and put it away. out of six total runs. my distributer has "walked " on me to the point that the car will not run. the last time was last night in the last time shot of the night. i heard some poping at the big end but, nothing to bad. after the run i shut it down and coasted on to the return road. i swiched it back to gas to cook the motor and thus shorten the time to put it in the trailor. everything was fine and then it just stoped.
it would not start. right there in the dark checking everything i could. did i knock a wire out taking off my gloves and coller, to seeing if the trigger light was strobbing with the box. finally the distributer had to be the cause. number 1 wire didn't look like it was in the right place. so i turned it. it was actually the seconf time i tried. the first time it seemed tight with some light torque of my hands. i didn't waant to send the timing to hell and back. so this time i put a little *** to it and sure enough it rturned and the car started.
so what could be causing this. the distributer is about 10 years old but it should be ok. but, is there something else? i'm a big guy and i craked that down the first time and my buddy alan is bigger than me and he put some *** on it. but, yet it does this..... twice now so i have to address this. i could check the timing ever single time. but, who wants to do that.
S/ST 1739
Carlos Mendes
BIZMANRACING is offline   Reply With Quote
