Old 09-21-2009, 09:06 AM   #1
68Mustang
Liked 2 Times in 2 Posts
Default Question about Santhuff springs
I was thinking about ordering a set of these springs for the front of my car. I called them and they said they needed to know the front end weight of the car. I don't have any way to find this. I know the car weighs @3200 w/driver has a small block with aluminum heads full interior and a 8 point roll bar.
Anyone have any idea what the front end weight might be or what spring i would need.
68Mustang is offline   Reply With Quote
Old 09-21-2009, 10:08 AM   #2
Chad E532
Chad E532's Avatar
Liked 54 Times in 7 Posts
Default Re: Question about Santhuff springs
Instead of popping for a set of four wheel scales, I have taken my car up to the local feed mill and they will weigh the front, rear, and total weight of the car on their truck scales. Last year I needed to know the weights to order some Cal Tracs rear springs and this method worked well and it only cost $5 or $10 to get it done. The resolution of their scale is 10lbs so it is not 100% precise but it will work well to find out your front end weight.
Chad
Chad E532 is offline   Reply With Quote
Old 09-21-2009, 03:11 PM   #3
Marty Rinehart Jr
Marty Rinehart Jr's Avatar
Location: Rineharts Performance Race Cars, Thomasville,PA
Liked 333 Times in 75 Posts
They are just trying to get you the right spring the first time. We use, and are a dealer for, Santhuff and they are the best shock or strut we have ever used.
Call me if you want to know anything about theur products.
717-793-6819
Marty Rinehart Jr
1125 SS STK SG SC SST
Marty Rinehart Jr is offline   Reply With Quote
Old 09-21-2009, 03:12 PM   #4
Rick Blake
Rick Blake's Avatar
Go to any of the larger truck stops...they will weigh you .02
Rick Blake 2395 SG, SC, SP
Rick Blake is offline   Reply With Quote
