Old 09-18-2009, 09:36 PM   #1
Ed Martin
Ed Martin's Avatar
Default Spark Plugs
I have a 69 chevy 255/290HP engine in SS. I just recently took the car off jack stands after 8 years and would like to know what spark plugs are good to run now. Thanks for any advice.
Ed Martin
SS/IA 910
Ed Martin is offline   Reply With Quote
Old 09-19-2009, 08:43 PM   #2
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Default Re: Spark Plugs
Ar12
Old 09-20-2009, 08:50 AM   #3
Wade_Owens
Wade_Owens's Avatar
Liked 3 Times in 1 Post
In all honesty, it really depends on what you want to spend. You can get really good plugs for about $5.00 each, or you can spend up to $15.00 a piece. I have used the Accel 137's with very good luck, they are available in lower heat ranges also. The AR73's also work. I would consider both of these an "economy" plug, they are between $4 and 5 each. Pick one and try it, you may have to adjust the heat range slightly, but you'll be in the ball park from the start. Then you can try the various other "faster" plugs out there.
Good Luck!
Wade
Old 09-20-2009, 11:05 AM   #4
novassdude
Liked 136 Times in 49 Posts
another question for you all.should a person use a resister or non resiter plugs with an msd ignition sysytem? Also does it mess with your memory tach's if you run the non resister plus?
novassdude is offline   Reply With Quote
