Old 08-30-2009, 09:10 PM   #1
Chad E532
Chad E532's Avatar
Liked 54 Times in 7 Posts
Default ET Drag Radials Spinning On Wheels
Today I made the first passes on a new set of 30x9x15 M/T ET Drag radials and after a couple runs I looked at the paint marks I had put on the tires to indicate where the valve stems were and I found that the LH tire had moved about 2 1/2" and the RH about 1". I was running 20psi in the radials so I am pretty surprised that they are spinning on the wheels.
Can a person install rim screws on a tubeless tire without leak issues?
Are there any other methods that do not require drilling holes in the rims?
Thanks in advance!
Chad
Chad E532 is offline   Reply With Quote
