Old 08-26-2009, 11:10 AM   #1
kmyers
kmyers's Avatar
Default Reading, PA Coverage
OK, hands up if you've seen W.J.'s interview after his first round of slip and slide. If you haven't, it is a "must see". W.J. for president (NHRA)
kmyers is offline   Reply With Quote
Old 08-26-2009, 11:28 AM   #2
racerron5
Default Re: Reading, PA Coverage
That was a rant that only WJ could do and get away with. He does speak his mind and most all of what he brought up was true. The fuel classes are out of hand and when corporate America can't afford to pay for them anymore, they will be out in the cold.
If you take away John Force and Don Shumacher you lose most of the key players. Then you lose the fan base, then everything else that goes with it.
Slow them down to the A/Fuel level and you would get some of those to jump into it. Actually take away the blowers altogether and rename A/Fuel to Top Fuel, do the same for FC's too. The cost goes down, participation goes up and after awhile nobody will really care about the difference. Nascar's car of tomorrow worked and nobody initially like those either.
Just my two cents.
And yes, WJ for president.
racerron5 is offline   Reply With Quote
