Old 08-14-2009, 05:06 PM   #1
junior barns
Liked 20 Times in 14 Posts
Default tranny gov shift ?
I have a rossler with auto 1-2 shift the gov was set to shift at 5800 with a 275 low gear.
what will this gov shift at with a 252 low gear??? Would have asked mr. rossler but they are closed til monday!!
Thanks in advance!
junior barns is offline   Reply With Quote
Old 08-14-2009, 07:04 PM   #2
Tony Curcio
Tony Curcio's Avatar
Liked 4 Times in 1 Post
Default Re: tranny gov shift ?
I never thought about it before, but I think it's a mathematical equivalency equation.
2.52 is .916 of 2.75, which means the output shaft is turning that much slower. So now the engine has to turn that much faster to get the governor spinning fast enough to make the shift. Divide 5800 by .916, you get 6330.
That's an educated guess. Please let me know what you find out for sure.
Tony Curcio 1860 STK
Tony Curcio is offline   Reply With Quote
Old 08-14-2009, 07:15 PM   #3
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
The governor shifts the tranny based on the output shaft rpm. That rpm will be the same but because the first gear ratio is 2.5 compared to 2.75. The engine will be turning slower at the shift point.
ss3011 is online now   Reply With Quote
Old 08-14-2009, 07:16 PM   #4
Tony Curcio
Wait, I think I got it backward. The numerically lower gear makes the output shaft spin faster at a given engine rpm, so you multiply 5800 by .916 and get 5312.
Last edited by Tony Curcio; 08-14-2009 at 07:19 PM. Reason: added "at a given engine rpm"
Old 08-14-2009, 07:18 PM   #5
Tony Curcio
Looks like we were posting at the same time. This was good mental exercise after a brutal day.
Old 08-14-2009, 07:26 PM   #6
ss3011
ss3011's Avatar
Plus as we shift lower and lower in rpm, the converter will be slipping more, so while the shift point to the output shaft rpm stays the same, the shift point to engine rpm will be different.
Old 08-14-2009, 08:33 PM   #7
Bill Grubbs
Liked 564 Times in 66 Posts
Don't forget to accout for the difference in acceleration rate. Theoretically it will shift at the same output shaft RPM. However the springs are affected by not only the RPM, but also the rate of acceleration.
I actually have the data on the computer from tests done in 2006, but it is not handy right now.
Bill
Found it 2.75 to 2.52 showed a 225 RPM rise in actual shift points. (Caveat...I believe it was the same springs and weights but I cannot find the setup book and therefore I cannot be 100% sure)
Bill Grubbs is offline   Reply With Quote
Old 08-29-2009, 09:15 PM   #8
junior barns
Bill your records were spot on! Saw a 300 rpm increase in the shift point using the same gov!!
Thanks for all the replies
