Old 08-11-2009, 05:43 PM   #1
skauto
Default 377 comp motor
377 ci motor all parts brand new never assembled, everything needed to make 900+ hp,GM performance block and splayed valve heads,bryant crank, titanium valves jessel valve train, jessel t-belt,msd front mount distributor,steph's oil pan and vacuum pump, weaver single stage oil pump, Gary Williams tuned dominator, grp rods, je custom designed pistons,as well as a set of je flat top pistons, 2 camshafts one for the custom high horse motor and one to work with the flat tops, off set roller lifters push rods etc...there are boxes of parts. more than i can list, right down to the gm performance valve covers. $10,000 usd, I will part this motor out. skauto@telus.net
skauto is offline   Reply With Quote
