Old 08-02-2009, 09:56 PM   #1
199k
Default Battery
What do you all use for a 12 volt battery. I've got the 1257 Rock and it sucks.. Doing research, the Braile looks the best because the specs say it has 200 more cranking amps...
I've got an 09 undercover with a CSR platinum starter, cranking a 615 BBC. Space is an issue with them if you dont know, battery goes all the way in the front.
Thanks for the help!!
199k is offline   Reply With Quote
Old 08-03-2009, 05:19 AM   #2
John DiBartolomeo
Default Re: Battery
If you have room for two batteries, then the CSR 24-volt system is tops. Nothing beats spinning over a big inch engine than 24 volts. As for batteries, both my cars have Odysseys from East Coast Auto Electric.
John DiBartolomeo
DRC Race Products
DragRacingActionOnline.com
Old 08-03-2009, 05:31 AM   #3
Barney B
Barney B's Avatar
Default Re: Battery
I solved all my problems with a Turbo Stat 16volt battrey.
BB
Barney B is offline   Reply With Quote
Old 08-03-2009, 06:48 AM   #4
THE LEGEND
Default Re: Battery
199k,
Have you called Rock to discuss the battery? I use their 16v stuff and love it.
Chip Johnson
THE LEGEND is offline   Reply With Quote
Old 08-03-2009, 06:50 AM   #5
THE LEGEND
Default Re: Battery
You may want to consider giving Mark Payne a call @ House of Payne and getting a good starter. I had issues with that start you are using cranking my 505. I replaced it with one of Marks with no more issues.
Chip Johnson
Old 08-03-2009, 09:08 AM   #6
Jason Oldfield
Jason Oldfield's Avatar
Liked 10 Times in 4 Posts
Send a message via AIM to Jason Oldfield Send a message via MSN to Jason Oldfield Send a message via Yahoo to Jason Oldfield
Default Re: Battery
I had been using Optima red top batteries for the last few years, but after a couple that didn't seem up to par I decided to try something different. So, I switched this year to the XS Power S1200 from Powermaster, and so far so good. It's a little smaller and lighter than the Optima, and according to the specs has slightly less cranking amps and reserve capacity (I run a 12V system with an alternator). But, if the outside construction is any indication of the quality of the internals, this thing is going to last (it really is a nice piece, and clearly built for racing).
I also decided to invest in a good automatic battery charger (one with logic that monitors the battery voltage and automatically shuts off when it is time). Overcharging of the battery leads to outgassing which significantly reduces the lifetime of AGM batteries. Schumacher Electric makes a couple that can be purchased for under $100.
Jason Oldfield
S/G & S/St 1838
Jason Oldfield is offline   Reply With Quote
Old 08-03-2009, 10:05 AM   #7
supergas565
supergas565's Avatar
Default Re: Battery
X2 for Odyssey, only use a single PC-1200 series and it hasn't let me down yet and I don't run a alternator either....!!!!!!! Also it's on it's fith year....!!!!!!!
Rick Blake
supergas565 is offline   Reply With Quote
Old 08-03-2009, 10:50 AM   #8
THE LEGEND
Default Re: Battery
Red Tops are made in Mexico now. The last few I bought did'nt hold up either.
Chip
Old 08-03-2009, 01:06 PM   #9
GaryGoFast
Talking Re: Battery
Had a pair of Otima Red Tops, went thru 3 flywheels in 14 passes[with CSR Platium starter] replaced with 2 16v Rock batteries, end of problems.
Gary Federico
S/St, S/G 1814
GaryGoFast is offline   Reply With Quote
Old 08-03-2009, 02:16 PM   #10
ERNIE GRIGGS
Default Re: Battery
I remenber that flywheel !!!!!!!!!!!!!!!!!!!!!!! Lol lol
ERNIE GRIGGS is offline   Reply With Quote
