Old 08-02-2009, 09:26 AM   #1
R. Thorne
Liked 101 Times in 34 Posts
Default stocker wiring
In stock, is it legal to remove the factory wiring harness under the dash and hood and replace with aftermarket panel with ignition switch on panel? Thanks, Ron.
R. Thorne is offline   Reply With Quote
Old 08-02-2009, 09:49 AM   #2
Woodro Josey
Liked 3 Times in 1 Post
Default Re: stocker wiring
Yes
Woodro Josey 2002 STK
Woodro Josey is offline   Reply With Quote
Old 08-02-2009, 10:56 PM   #3
R. Thorne
Thanks, Woodrow. Ron.
Old 08-03-2009, 09:00 PM   #4
Jesse Knapp
Which is better? My Nova has original wiring and is in good shape.
Jesse Knapp 4899 STK, SS
Jesse Knapp is offline   Reply With Quote
Old 08-03-2009, 09:03 PM   #5
Jesse Knapp
Forgot to add that I'm just starting the stocker build with it.
Old 08-03-2009, 11:38 PM   #6
Jeff Lee
Jeff Lee's Avatar
The first thing I did when I started building my AMX to a STocker was replace all the wiring with a painless kit with switch panel, fuse panel and relays where appropriate. After 25+ years on the road, numerous stereo systems, CB's and assorted other splices and dices, it was a job that needed to get done. I've seen some real rat's nests for wiring in the pits. Imagine your in your first final...you go to start the car and it a smoldering puff comes from behind the dash. Would it be worth the risk?
Jeff Lee 7494 D/S '70 AMX
