Old 07-14-2009, 02:08 PM   #1
Clint
Default ***GMR Aluminum Stacker*** For Sale
32 ft. aluminum GMR stacker ( 37' overall). 3 8000lb. axles, electric brakes, Alcoa wheels,
6 new Goodyear LT235-85R16 load range G tires, 11 ft. 8 in overall height, 62 inch double side door, stainless steel locks and latches, 23 ft custom built GMR lift, 8 foot carpeted attic, 8 ft. X 8 ft. stainless steel counter top, 2 Lista tool boxes, 2 spare tires, insulated walls, 110 volt light package, 3 exterior flush mounted 500 w. quartz lights, 8 D/rings top and bottom, 2 new 1000 amp. Delco Freedom batteries, 6500 w. Onan Gas generator in polished stainless steel enclosure with 25 gallon aluminum gas tank, L-shaped cabinets (carbon fiber laminate) top and bottom, 12 v. light package, air line package front, rear and pit side, 110 volt oil less air compressor with commercial grade tank in attic, 2200 w. inverter (for computers and radio), am/fm stereo, cd player all with amplifier, ramp door with full size heavy duty ramp extension, hydraulic landing gear, LED lighting, 12 v battery charger, shore power outlet with cable, 2 pit pal fuel jug holders, 15 gal each (in attic), 12 v winch, wheel house is carpeted, polished stainless steel corners and rear area above door.
$49,000
Call: (630) 595-1240 or (630) 253-9951
Email: JBlezein@aol.com
Located in suburban Chicago
Clint is offline   Reply With Quote
