Old 07-06-2009, 10:45 AM   #1
mannymen
Liked 13 Times in 7 Posts
Default Cutlass & Chevelle 70-72
Are the suspension, motor mounts and trans mounts from a Cutlass & Chevelle for the years 70-72 the same? I would assume yes since they are both A bodies within the same years. Looking at possibly swapping in a SBC/BBC & powerglide into a 72 cutlass that currently has an olds 350 3 speed auto.
N/A
mannymen is offline   Reply With Quote
Old 07-06-2009, 02:23 PM   #2
Jim Kaekel
Liked 535 Times in 110 Posts
Default Re: Cutlass & Chevelle 70-72
The only thing that I know that is different are the motor mounts. Just change the frame pads/motor mounts, simple bolt-on. Trans-Dapt even sells a bolt-on kit for the install, or just get the mounts/frame pads from a Chevelle frame.
Jim Kaekel 3836 STK
