Old 06-21-2009, 07:39 PM   #1
Tony396
Default LOADS of 305/283/327 parts..CHEAP....LOOK!
I ended up with this stuff and I have no use for it.
10 good dismantled 14014416 cylinder heads. No visible cracks after disassembly. $250 takes all 10 or best offer.
4 good 305 2 piece rear main seal blocks. Three are part number 14010201 and one is 203. Also have one 1 piece rear main block and the number is somewhat unreadable...looks to end in a 783. Take all 5 blocks for $300, or $100 each separate.
305 intakes: 3 of part number 14057053 and 2 of part number 14014432. $125 for all 5.
Late model 350 motors. One complete motor-accessories, carb, ignition, etc..block casting number 14038548 and the other is a complete short block and heads 14093638. $125 for both.
283 heads 3795896 and block 3794226-Bare, standard, decent shape $100
327 block 3782870 G 22 5-Standard also...$250
All parts are located in central NJ right off exit 7 of the NJ turnpike or exit 57 of I295. I will not ship these items but I can help you load. I have some pics I can send you. Please email me direct at stocker1042@hotmail.com
Thanks
Tony P
Tony396 is offline   Reply With Quote
