Old 06-12-2009, 03:11 PM   #1
Stewart Way
Liked 70 Times in 22 Posts
Default looking for water pump dimensions
Putting a motor plate on a 5.7 Hemi and need to find a water pump that will fit. The inlets to the block are 9.75 center to center. If you have a pump laying around could you measure it to see what it measures. If someone finds one close to 9.75 I can then get a CSR type pump for that application and mount it on the plate. Thanks
