Old 06-10-2009, 07:59 AM   #1
chase williams
Liked 6 Times in 2 Posts
Default Comp and Super Stock Parts
7 1/2" Trick Titanium bellhousing, chevy pattern with liberty candlestick. Refer to racingjunk.com ad #1539605 $1250
8 5/8" Trick Titanium bellhousing, chevy pattern with liberty candlestick. Current certification. $1900
Liberty Equalizer 5 speed w/ shifter. Available as 3.16,2.16,1.59,1.24,1.00 or 3.33,2.22,1.59,1.24,1.00. Trans has welded clusters it is not "Z" style. Refer to racingjunk.com ad# 1569720 $4500
358" Greg Stanfield Pro Stock Truck mid-deck engine. Slawko heads, HRE intake. All good pieces. Refer to racingjunk.com ad #1553271 $19,000
299" David Cook/R.E.D. wedge engine. CFE heads, HRE intake, comes complete with 2-750 carbs and single 750 carb setup. All the best pieces! Front runner anywhere. 8 runs since fresh. Refer to racingjunk.com ad #1525368 $29,500
New EasTexas Racecars '92 Camaro. Needs assembly. Comes complete with the pieces needed to race Super Stock GT including engine, trans, and 3rd member. $25,000 or less engine and trans $19,500. Refer to racingjunk.com ad#1348704 for more info and photos.
7" DZE steel flywheel with studs 142t $500
2006 15* CFE Wedge Intake 8.200 deck. with 2-750 carb top $750
A-1 7" torque converter C300-66 $400
Contact Chase Williams for more info (903)692-2150
chase williams is offline   Reply With Quote
