Old 06-09-2009, 09:25 AM   #1
FED 387
Liked 333 Times in 180 Posts
Question power vs. manual windows in 3rd gen camaros
Anybody know if 82-92 firebird/camaros were available with manual windows or did they all come with power windows???? If so what years were manual offered??? Thanx Dick
Old 06-09-2009, 10:17 AM   #2
Chad Rhodes
Default Re: power vs. manual windows in 3rd gen camaros
yes, even some 4th gen cars were. however the power window isn't much heavier and is way more convenient
Chad Rhodes 2113 I/SA
Old 06-09-2009, 11:11 AM   #3
Dragsinger
Liked 99 Times in 60 Posts
FED, I have seen a "few," but very few manual windows. Like posted above, I can not see the weight difference being worth any effort to change over.
On the other hand, if a fellow had the doors off or torn down to remove the crash bar, and had the manual parts, well, might be a consideration. Plus, you could remove two or three pounds of wiring.
Larry Woodfin 471W
Old 06-09-2009, 11:19 AM   #4
FED 387
thats what I'm thinking---Thanx for the replies guys--dick
Old 06-09-2009, 11:19 AM   #5
Buicksstage1
Buicksstage1's Avatar
I know in are A bodies, power windows are lighter then manual.....chris
72GS stage2 455 street/strip best et 9.93
1970 Stage1 iron heads,stock rods. 1.37 60' 10.17@129.8
70 GSX clone, 9.3:1 455 stage2 best et 11.00
Buicksstage1 is offline   Reply With Quote
Old 06-10-2009, 08:41 AM   #6
Tim Kish
Liked 11 Times in 4 Posts
I know for my car power windows are lighter than manual and when belted in I couldn't reach the window cranks - power windows are sooo nice to roll up when you pull into water and down after making the turn when its mid summer.
Tim Kish
3032 SS/GS
Tim Kish is offline   Reply With Quote
Old 06-10-2009, 05:14 PM   #7
Signman
Liked 269 Times in 99 Posts
It's doubtful there is much of a weight savings in manual windows. Have been told power windows may actually be lighter.The motor is very small. The crash bar does not weigh much either. But every little bit can count.
The doors are long and that piece of glass is a tank. That is where the weight is. See if replacement glass is thinner and therefore lighter.
Old 06-12-2009, 07:15 AM   #8
bert powell
Liked 34 Times in 12 Posts
Wink Re: power vs. manual windows in 3rd gen camaros
The crash bars are 17# each side on 82-92 f body if you remove the whole thing. As for power verses manual, I have not weighed the parts but would guess they are close to the same. Replacement glass (thinner) is an option if funds are unlimited.
bert powell is offline   Reply With Quote
Old 06-12-2009, 01:38 PM   #9
Ed Wright
Ed Wright's Avatar
'93/'02 crash bars don't weigh much at all. I was told about eight lbs each, but when I got mine out it was more like eight lbs total. Bolts and all. Just stamped a piece of channel stamped out of sheet metal, and not all that thick.
Ed Wright 4156 SS/JA
