Old 06-07-2009, 06:37 PM   #1
slick5861
Liked 2 Times in 2 Posts
Default Afco Ball Joints
I`ve got a 65 Malibu SS,355, powerglide. Would there be any benefit to installing the upper ball joints under the mounting flange opposed to on top,as it comes from the factory ? Mounting them underneath would make them longer by approx. 1/4 inch. They are the Afco low friction Ball joints. Thanks for any input.
slick5861 is offline   Reply With Quote
Old 06-07-2009, 09:12 PM   #2
Jim Cimarolli
Liked 166 Times in 46 Posts
Smile Re: Afco Ball Joints
Mounting them under will help the camber problem at full front end lift, but I would recomend the Howe extra length ball joints. With them the tire will be straight up at full lift, not leaning in at the top.
Jim Cimarolli is offline   Reply With Quote
