Old 05-28-2009, 04:18 PM   #1
Greg Greening
Liked 4 Times in 2 Posts
Default 87 Camaro stocker drivetrain
Engine is 305 215hp 245 NHRA tune port with Jim Lewis heads Manley valves PAC beehive springs CP pistons Mile high cast crank Bullet cam Schubeck lifters Complete intake to pan with Holley 950 computer Coated headers with Performance welding merge collecters and tune up SPARE 181 bowtie block and head castings $9000 obo Jerico 4 spd trans 3.29 low 2.00 second 1.39 third New Advanced 10 in clutch lightweight flywheel long shifter Lakewood bellhousing just recertified $4000 TRANS IS PACKAGE WILL NOT SEPERATE KTRE 12 bolt 33 spline Moser axles gundrilled lightened steel spool lightened 5.38 Pro ring & pinion titanium wheel studs Aluminum drums Pete Z control arms QA1 shocks Two rear sway bars $2500OBO Will not separate any of these pieces other than described Call for more info 573 864 9706 or email Greenstk594@aol.com
Greg Greening is offline   Reply With Quote
