Old 05-26-2009, 08:39 PM   #1
racer913
Default tire pressure
I have a 1968 camaro 3100 lbs split leaf springs and cal tracs 434 SBC glide with a 1 81 first gear and 4 11 rear gears with a 5000 stall converter slicks are Hoosier radials 30 by 10 what kind of air pressure should I be running?
racer913 is offline   Reply With Quote
Old 05-27-2009, 03:31 AM   #2
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
Default Re: tire pressure
With that tire I would start at between 18-21 psi. Track prep makes a huge difference.......
Old 05-27-2009, 01:45 PM   #3
racer913
thanks I ben seeing same tire/car combo with little to no wrinkel I run 20 lbs and works pretty well just wanted some info
Thanks again
Old 05-27-2009, 08:46 PM   #4
72Malibu
72Malibu's Avatar
I use the 30x9x15 radial slicks, set them at 18psi when I arrive at the track while sitting on the trailer, seems to work for me
*** 72 Malibu ***
1.329-3.99-6.28@106.71-9.98@131
best 60ft to date-1.2997
72Malibu is offline   Reply With Quote
Old 05-28-2009, 01:58 PM   #5
sportsfan
The tire pressure everyone is suggesting ,is that with or without tubes? I have a 3300lb Malibu (Hoosier28x10 non radial) and was wondering what pressure to run.
sportsfan is offline   Reply With Quote
Old 05-28-2009, 04:18 PM   #6
tireguy
On the radial tires I would start at 20 and go from their depending on the track.I have seen some people running as much as 30 in them.The bias tires you going to start at around 12 and go up from their,until the car does not hook and then go back down a little.But all this is on how good the track is,and on how good the car works.
tireguy is offline   Reply With Quote
