Old 05-21-2009, 06:02 AM   #1
Ian Hill
Ian Hill's Avatar
Liked 6 Times in 3 Posts
Default Batteries
it is time for new batteries. i run stock with a 67 chevelle with most of the orginal wiring still in tact, and i fire the car with the key. would 16 volt batteries hurt any of the orginal equiptment? i am caught up in deciding to choose the 16 volt system or a set of optimum batteries. any insight would be appreciated. i already have a power master alt.
thanks
Ian
Ian Hill is offline   Reply With Quote
Old 05-21-2009, 10:25 AM   #2
mannymen
Liked 13 Times in 7 Posts
Default Re: Batteries
DRR has had this same discussion last week. search batteries
N/A
mannymen is offline   Reply With Quote
Old 05-21-2009, 10:26 AM   #3
junk496
I run a 16 volt battery with no alt.In my 1987 monte ss and still has the factory wiring in it.I do have an electric water pump and fan that runs of a yellow top battery thats in the trunk so this way all the jucie from the 16 volt battery gos to the ignition system.No problems at all and with a full charge on both batteries I get about 5 to 6 full runs in, thats with a 454 bbc.Oh,I have been running this way for about 4 years.
junk496 is offline   Reply With Quote
Old 05-21-2009, 01:19 PM   #4
Ian Hill
Ian Hill's Avatar
so how does your battery disconnect switch get hooked up.
Ian
Old 05-21-2009, 03:11 PM   #5
junk496
I dont have one.My 16 volt battery is still in the stock location up front.
Old 05-22-2009, 07:54 AM   #6
B Aceves
B Aceves's Avatar
Liked 7 Times in 4 Posts
Ian.
There is a company AGM electrical that makes a dual post trick battery that has 16 volt on one
post and a 12 volt lug on another all in one battery. The 12 volt lug lug you can run anything you
think will not handle 16 volt. I recomend calling the manufacture of anything you run aftermarket
and make sure it will handle 16 volt first. I know for sure all MSD ignition will handle 16 volt
thus you can run everything threw the master disconnect with this battery. BTW this battery
you can purchase threw Jegs or direct. Good luck.
Bob Aceves,
746 E/SA
A&M motorsports
B Aceves is offline   Reply With Quote
Old 05-25-2009, 01:48 PM   #7
CrateCamaro
CrateCamaro's Avatar
Liked 19 Times in 7 Posts
keep an eye on the weight of the batteries
Tony Valerio 1968 Camaro
1700 IHRA H/CM
1701 NHRA SS/?A
Old 05-25-2009, 06:08 PM   #8
Wade_Owens
Wade_Owens's Avatar
Liked 3 Times in 1 Post
Originally Posted by B Aceves View Post
Ian.
These type batteries will get what is called a "cell imbalance". Please check and ask around before purchasing any 3 post. I had one and it didnt start the car at the worst possible time, (you know when that is, right?)
Wade
Old 05-28-2009, 06:15 PM   #9
B Aceves
B Aceves's Avatar
Wade
Wade.
But isnt it possible for any battery to get a cell imbalance?? I belive so, I dont think you can blame
just the three post on that. It is possible to run everything on the 16 volt I only sugjested the dual post
for the question at hand if its a problem with this type of battery I certainly would like to know more about this if its is a real issue. Thanks, not trying to hijack the thread.
Bob Aceves,
746 E/SA
A&M motorsports
Old 05-29-2009, 05:46 AM   #10
Ian Hill
Ian Hill's Avatar
thanks for the responses, i hate to admit it, but i am buying delco replacements until i see the 16 batteries in action in a car with stock wiring, thanks for the responses, you've all at least given me the background info to start the home work with.
thanks
ian
