Old 05-12-2009, 10:12 PM   #1
Watson Racing
Default Need help finding my (grimlin)
I have a super street car that runs mid 10s car has been running great at the start of the season all the sudden i have a problem. When i jab the pedal to the floor it falls on its nose then picks right back up if i push the pedal down slow it is fine I have taken the carb apart and cleaned everything even put new accelerator pumps in and new power valve in even cleaned pump nozzles it is a quick fuel 850 check timing check valves even checked msd box everything checks ok also put in new plugs drained all fuel and changed fuel filter even changed fuel any one have any help
THANK'S TO ALL WHO POSTED I FOUND THE BOTTOM OF THE INTAKE GASKET WAS LEAKING BUT I DID USE ALOT OF EVERYBODY'S IDEAS AND MY CAR IS RUNNING BETTER THAN IT EVER HAS.
Thank's for all you help
Watson Racing is offline   Reply With Quote
Old 05-12-2009, 11:10 PM   #2
Chris Williams
Chris Williams's Avatar
Default Re: Need help finding my (grimlin)
Had a nearly identical problem this past weekend (although on a Dominator). Did three things, and it went away -- unfortunately not sure which one was the solution. What I did: a) put in somewhat bigger idle air bleeds, b) put in bigger accelerator pump squirters, and c) asked the driver to roll into it rather than stomp it. Problem solved.
Chris Williams 6304 SC, TD, ET
Chris Williams is offline   Reply With Quote
Old 05-13-2009, 03:50 AM   #3
Barney B
Barney B's Avatar
Make sure one of you idle air bleads are not plugged. It don't take much.
BB
Barney B is offline   Reply With Quote
Old 05-13-2009, 08:34 AM   #4
buzzinhalfdozen
Liked 11 Times in 8 Posts
Quick way to check for plugged idle air bleed run the adj. screw in if no change in idle spped someting is restricting the circuit. Had this on a SS car at indy took carb apart to inspect, cleaned out never did see anything but after reass. carb problem was gone. Joe
Joe Buchanan SS/BX 3117
Old 05-13-2009, 08:46 AM   #5
sean graham
make sure your idle air screws are about 1 1/2 turns out from fully closed, and then put a bigger front squirter in the thing, you should be ok then
sean graham is offline   Reply With Quote
Old 05-13-2009, 01:10 PM   #6
H.A.A.C. Racing
H.A.A.C. Racing's Avatar
I go with bigger squirters
H.A.A.C. Racing is offline   Reply With Quote
Old 05-19-2009, 04:58 PM   #7
voltdr
Liked 100 Times in 51 Posts
Bigger squirters, ( mine are .055 in my dragster) and make sure the engine is warmed up properly. It is a bigger issue also if the weather is cooler outside. The problem will show up more when it gets cool at night vs. the daytime, even at the same race.
voltdr is offline   Reply With Quote
Old 05-20-2009, 02:33 PM   #8
EricArrow
EricArrow's Avatar
BB
I agree...
Low and Slow
EricArrow is offline   Reply With Quote
Old 05-20-2009, 03:11 PM   #9
Bryan Gillespie
Banned
Clean Fuel Filter ?
Bryan Gillespie is offline   Reply With Quote
Old 05-20-2009, 04:59 PM   #10
Mark Schmidt
Mark Schmidt's Avatar
I'm assuming you run on the stop, that said I would suggest 3 things
1. Lose the power valve and re-jet accordingly
2. Larger squirters
3. Roll into the throttle (if for no other reason..consistency)
Just my .02 cen ts...good luck!
MDS Motorsports
Mark Schmidt is offline   Reply With Quote
