Old 05-12-2009, 04:39 AM   #1
Joe Rakowski
Default Operation has to go!
2008 Ken’s Kustom Chassis 270” Slip Tube Top Dragster. 24” wide cage. Will fit tall driver. 7 point Simpson belts, ISP cage padding. Aluminum body currently wrapped. Fabricated 9/9.5” floater rear with Strange Ultralite 9.5” carrier with 4.10 gears. Carbon fiber brakes. Carbon Fiber mono strut rear wing. Carbon fiber hood scoop. Weld Aluma Stars front and back. Bead locks on rear. Goodyear rubber all around . Slicks are 34.5X17-16 D1022 with only 4 passes. Racepak digital dash with V300 data logger. Sensors include oil press, oil temp, water temp, fuel pump press, carb press, trans oil temp, nitrous bottle pressure, nitrous fuel press, vacuum press, 8 EGT’s, 2 O2’s, and drivershaft RPM. Biondo 400 delay box. Dual Stroud chutes. Product Engineering fuel pump. Powermaster 16 Volt battery. MSD Programmable Digital 7 ignition.
Engine: 598 BBC Dart block, Crower crank and rods. 1201 Brodix heads with titanium valves. Comp Cams big bore cam, T&D Rocker system, 7/16 Manton pushrods. Olson dry sump pan, Wulff Pumps 4 stage dry sump oil pump. Peterson 7 qt oil tank. Profiler cast tunnel ram with 2 1150 dominators by Nickerson. Also comes with single 4 barrel top and Brodix single plane intake. Single stage Speedtech Tech 1 system. 6 bottles included. Performance Welding stainless steel headers. Jesel belt drive. Engine just freshened.
10 Clutch BTE powerglide 1.80 straight tooth just freshened by Ken Moses with Hughes converter.
Turnkey $65,000.00
2005 Kens Kuston Chassis 240” Swing arm dragster. 24” wide cage with adjustable pedals. One piece fiberglass body, currently wrapped. Weld Aluma Star front and back. M/T tires on the front, Goodyear slicks on the rear. 33X16-15 D2052. Stroud seat belts and chute. Racepak recordable digital dash. Biondo Mega 400 delay box. Product Engineering fuel pump. 16 volt battery. Digital dial board. MSD Programmable Digital 7 Ignition.
Engine: 580 BBC World Products Merlin block. Crower crank and rods. CP pistons, Brodix 1803 heads with titanium intake valves. Comp Cams big bore cam, T&D rocker arms. 7/16 Manley push rods. Miezer water pump. Olson oil pan. Star vacuum pump. Edelbrock intake with both 1250 gas carb and 1250 alcohol carb by Nickerson. #1 under carb 2 stage stop and Biondo in line stop. Powder coated Dynatech headers. Engine has less than 30 passes since freshened.
8 clutch Powerlglide 1,76 straight tooth by Ken Moses just freshened and powder coated. B & M converter.
Turnkey $35,000.00
1970 Chevy Nova AA, A, B/SA. 402 BBC. Sleeved 454 block. Aluminum heads by Spyder, Aluminum intake. Comp Cams big bore cam, Shubeck lifters, Holroyd 9/16 rockers. Holroyd Carb. ATI converter, Kilgore ultralite 3sp. Sthal Headers with megaphone collectors. 2-16 volt batteries. MSD 7AL ignition. Full cage with Stroud belts. Moroso front springs, split mono leaf on the rear with Cal-Tracs. Competition Engineering shoks on the front, QA1’s on the rear. 12 bolt by Moser with ford ends. 4.56 gears. Wilwood master cylinder and disc’s all around. Framed notched for oil pan removal. Weld Aluma stars all around. M/T rubber all around. Radials on Rear. Holley fuel pump. .
Turnkey $30,000.00
2003 Renegade 30' motorhome built on a Freight liner Columbia chassis. 56028 miles, 425 CAT w/10spd smart shift. Air ride seats and power levelers. 1 living room slide. 2 60 gal saddle fuel tanks. Queen sized bed, 2 sofas, dinette, over the cab bunk. Plenty of storage. 1 yr sat dish can get DISH or DIRECT 12.5 kw onan diesel generator. Refrigerator, 3 burner stove with oven, micro wave, coffee maker. Sony TV's front and rear with DVD/VHS players. Stero. Full bath with oversized shower. 200 gal fresh, 90 gal grey, 54 gal black tanks. 20' power awning. 40,000# hitch Well maintained and in very good condition inside and out.
2003 United Express 30' Stacker trailer. Triple axel, extruded aluminum floor. 16' inside lift with 9' overhead storage. L shape base and overhead cabinets. Plenty of tool boxes, nitrous rack, etc. Hydralic landing gear. 9' high ramp door with winch and extension. 5000# winch, air compressor with 4 outlets, 25' awning. Stereo. Very good condition.
Motorhome $125,000
Trailer $20,000
Package $140,000
Joe
610-220-6020
Joe
1007 A/SA
107J S/C
Joe Rakowski is offline   Reply With Quote
