Old 05-08-2009, 10:06 AM   #1
Smitty
Smitty's Avatar
Default Cubic Inch/Weight Break for SS/CM and SS/DM
Does anyone know the Cubic Inch limits AND weight limits for SS/CM and SS/DM?
Smitty
Smitty is offline   Reply With Quote
Old 05-08-2009, 10:22 AM   #2
John Mason
Default Re: Cubic Inch/Weight Break for SS/CM and SS/DM
From the rulebook:
SS/CM - 9.50 to 10.49 lbs per CI - 2850 lbs minimum, includes driver.
SS/DM - 10.50 to 11.49 lbs per inch, - 2950 minimum
John Mason 7743 SS
John Mason is offline   Reply With Quote
Old 05-08-2009, 10:39 AM   #3
Smitty
Smitty's Avatar
Jason,
Thanks for the reply, one more question however; what is the rule for the carb and do you add the 170 to the weight amount after you do the math with cubic inches to the weight break ie: 300 ci x 9.5lbs = 2850 + 170 = 3020
Smitty
Old 05-08-2009, 10:57 AM   #4
J Slane
Smitty, Are you going to Lakeland.....Jay
J Slane is offline   Reply With Quote
Old 05-08-2009, 11:16 AM   #5
Tracy Robbins
Liked 25 Times in 11 Posts
You don't add 170 lbs for the driver for the modified classes. Actually, it's just the opposite if you run an automatic transmission you can deduct 5 % from the total. In your example it would be 300 x 9.5 = 2850 x .95 = 2708 which I think would round up to 2710. Hope this helps.
Tracy Robbins
SS 9766
Tracy Robbins is offline   Reply With Quote
Old 05-08-2009, 11:47 AM   #6
Smitty
Smitty's Avatar
Thanks Tracy, it clears it for me I really appreciate it.
Smitty
