Old 05-04-2009, 12:19 AM   #1
skauto
Default comp motor
377 ci A/ED motor all parts brand new never assembled, everything needed to make 900+ hp ,GM performance block and splayed valve heads,bryant crank, titanium valves jessel valve train, jessel t-belt,msd front mount distributor,steph's oil pan and vacuum pump, external oil pump, Gary Williams tuned dominator, grp rods, je custom designed pistons,there are boxes of parts more than i can list right down to the gm performance valve covers. all design work done for heads just not finished.I will supply info on finished port design or you can have them finished to your own program. 15,000 usd, I will deliver as far as Blaine WA.
skauto is offline   Reply With Quote
Old 05-13-2009, 06:01 PM   #2
skauto
Default Re: comp motor
any offers? did I mention these parts are BRAND NEW never run,
