Old 04-24-2009, 12:28 AM   #1
trmnatr
Default JW Performance Transmission "Ultra Comp" Opinions, ATI question
I have used and suggested many customer to use JW Transbrakes, "the wheel" and Ultra Bell
Im thinking about trying a converter from JW, Im looking at the custom Ultra Comp line. Below is some info about them as stated in there book. What are your opinions ?
The JW Performance Ultra-Comp converter series is compromised of the finest converters made. All of the competition converters are custom designed and hand built for each individual application. Available in 7", 8", 9", 9.5", and 10" sizes, each converters stall speed is individually selected for your cars application. Ultra-Comp converters are capable of handling any amount of power, from any size motor, with any kind of power adder. Each converter is built from the highest quality custom made cnc machined components, which allows us to provide a full 1 year warranty. Each Ultra-Comp converter comes with one free stall adjustment within 90 days of purchase, so that you recieve peak performance from your converter. Based on your application, JW's Ultra-Comp converter is available with an ultra strong steel stator or JW's custom aluminum stator.
The Ultra-Comp converter has the following features:
Furnace brazed fins
Precision ground neck
CNC machined steel turbine hub
CNC machined crank pilot
New mounting pads
Heavy duty sprag components
Torrington bearings throughout
Anti-Balloon plates (if required)
So what do you think about the JW Ultra-Comp converter ?
trmnatr is offline   Reply With Quote
