Old 04-10-2009, 06:57 PM   #1
Brad Plourd
Liked 67 Times in 20 Posts
Default SBC 18 degree Comp/SS short block
GM Bowtie block with steel splayed caps. 50 mm roller cam bearings. Comp Cams Comp Eliminator custom grind .800"/.792" with 1.7 rockers. Bushed lifter bores. PBM .842" roller lifters. Jesel belt drive. MSD front drive distributor. MSD Crank trigger. MSD HVC II coil. CSR Water pump. Peterson external oil pump. Stefs pan. Eagle ultra race light weight crank (3.250" stroke). Bill Miller billet rods. Bill Miller pistons lightened by Rebco, coated pins. ATI super damper.
3 time national event winner in Super Stock. Multiple divisonal event winner. Division 6 championship in '08.
Last freshened by Lambeck Ent.
2 spare pistons, extra set of rods, extra cam and lifters.
Change pistons only to make your SB2, splayed valve, 23 degree, 15 degree, 12 degree or 23 degree heads work.
$4500
http://i307.photobucket.com/albums/n...r/CIMG2191.jpg
http://i307.photobucket.com/albums/n...r/CIMG2192.jpg
http://i307.photobucket.com/albums/n...r/CIMG2193.jpg
http://i307.photobucket.com/albums/n...r/CIMG2195.jpg
http://i307.photobucket.com/albums/n...r/CIMG2196.jpg
Brad Plourd is offline   Reply With Quote
