Old 04-06-2009, 08:59 PM   #1
herbjr
Liked 83 Times in 32 Posts
Default Cant believe what I saw today
Well I took my 340 Super Stock Modified motor apart since we had some problems on the 2nd run and I must say after buying the car turn key with zero runs you never know what you are buying. I'm not blaming anyone that has owned the car but I almost threw up when I saw the crank had over 25 holes to balance it. Over 8 of them were bigger and deeper than my thumb. I have never seen a butcher job this bad on a crank and we did engine work for 8 years. I called Callies today and they had one they could send me right away balanced to my bob weight and I should have it in a week. Its a shame that someone spent GOOD money to have this motor built and got a stock crank that was butchered so bad. I guess im going back to a convertor/gear combo we ran 15 years ago to get a base line. Hope to have it at Rockingham but if not Petersburg for sure.
Herb Jr
herbjr is offline   Reply With Quote
Old 04-06-2009, 09:15 PM   #2
Dustin Ward
Liked 4 Times in 2 Posts
Default Re: Cant believe what I saw today
Sorry to hear that, but it sounds like you'll have it back up and going in no time. We are all too trustworthy at times , i just bought a set of slicks from across the country to have them arrive and be so dry rotted there is no way I would put them on a car.
Live and learn is all we can do.
Dustin Ward is offline   Reply With Quote
Old 04-07-2009, 11:32 AM   #3
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Unhappy Re: Cant believe what I saw today
Damn Herb! That crank must have looked like swiss cheese!
Dustin, I did the same thing a few years ago, bought some tires from a major performance parts company. When I got them one was fresh and new, the other was about as dried out as a tire could be. I noticed they came from different suppliers. Both from different parts of the country!
The only place to by tires is at the track! From the tire makers! Jim
Old 04-08-2009, 03:21 AM   #4
RJ
I had a motor in for a freshen up from a former NHRA world champion comp eliminator builder a few years back. I could not believe the 2nd tier parts/shoddy clearances in this motor! - It's amazing to see what some will try to get away with, thinking that no one else will ever see what they've done.
RJ is offline   Reply With Quote
Old 04-08-2009, 11:50 AM   #5
treessavoy
Liked 4 Times in 4 Posts
I'm not high jacking the thread but I have a question.
Would it not be better to remove the weight from as far out on the counter weight as you could before you start drilling towards the center?
Herb,
Had the same thing happen by an AL machine shop that supposedly had built a number of IHRA record holders. Took the second crank to Ed Chandler in Anniston, a one man speed shop, and still have the crank today.
Old 04-08-2009, 05:24 PM   #6
herbjr
Well 2 things, either order a Callies to bob weight or turn the counter weights down in a lathe. For a motor making this kind of power an aftermarket crank would have been a little better.
Herb Jr
Old 04-09-2009, 03:25 PM   #7
mtkawboy
Liked 54 Times in 18 Posts
You know you have a top quailty engine machine shop when you get the clutch face side of the flywheel back from them drilled to balance it. Terrill Motor Machine, Hollywood Fla.
mtkawboy is offline   Reply With Quote
Old 04-09-2009, 03:40 PM   #8
Jim Wahl
Jim Wahl's Avatar
Red face Re: Cant believe what I saw today
You are kidding...... right? Jim
Old 04-09-2009, 03:53 PM   #9
THE LEGEND
Herb,
Similar circumstance with the dragster I just bought. Intake was leaking could not get it to seal. The heads are in sad shape one end looks like someone took a hammer to it. The previous owner told me to put it back and use a lot of silicon. I pulled it out and it's in the back corner of the shop. Luckily I was able to obtain another motor.
Chip
THE LEGEND is offline   Reply With Quote
