Go Back   CLASS RACER FORUM > Class Racer Forums > Competition Tech
Old 03-27-2009, 05:19 PM   #1
art leong
Default Plug gaps?
The motor I'm running is the first higher than stock (12.7 to 1) compression ratio motor I've done. I've always gapped the plugs at stock specs (on my stockers) or at .050 on our hemi stocker (30 years ago).
The stock specs for my motor (2.4ltr, 4 cyl dodge) are .045. Stock compression is 9.5 to 1.
I'm presently using stock champion plugs. What should my gaps be set at?
Art Leong 2095 SS
Old 04-03-2009, 11:02 AM   #2
Jeff Lee
Jeff Lee's Avatar
Default Re: Plug gaps?
The gap isn't an issue but the heat range will be. Just make sure you go colder than stock. Could be quite a bit.
Jeff Lee 7494 D/S '70 AMX
Old 07-10-2009, 07:31 AM   #3
Evan Smith
Liked 115 Times in 5 Posts
Art,
I have tried everything from .035 to .070 on my Stocker with no difference either way in performance. I like the small gap, especially in forced-induction applications. In chassis dyno testing I've seen some flutter in the graphs at high rpm that I attribute to a slight misfire. It instantly goes away when we take down the plug gap.
BTW, Justin is a real nice guy.
Evan
Evan Smith 1798 STK
Evan Smith is offline   Reply With Quote
Old 07-17-2009, 02:37 PM   #4
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Thumbs up Re: Plug gaps?
After talking to George Widuch, who built the engine in my Volare, he said the pendulum is swinging toward the lower gap specs. Dyno testing and on-track testing seem to bare out that theory that as long as your ignition system is up to snuff wider plug gap does not make more power. A plus to this is your plug wires will last longer and chances of a high RPM miss less likely. Jim
Old 08-20-2009, 07:54 AM   #5
Ven302
Ven302's Avatar
Liked 34 Times in 7 Posts
Way back, we found on some street supercharged cars that the "candles" seemed to be getting blown out as boost and of course rpm increased, the guys were using some plugs advertised to be "all the stuff"
some unobtanium material, 37 ground straps (get the picture) I swapped the plugs to an NGK race plug
R567X-x type of part number advised to gap at .025 and voila the lights stayed on!, Also in my Suburban
I had a local shop do a new exhaust (hate working on street stuff) they put some platinum whatsit plug at .065 gap, the truck would misfire towing on anything but a gentle acceleration (turtle). I put some non resistor autlite race plugs, 2 ranges colder and .030 side gap and the problem went away.
My point? Go at least two maybe three colder, you can find charts on how to read the strap for heat range, non resistor and keep the gap low there will be little gains in a big gap and much greater chance of misfire.
Ven302 is offline   Reply With Quote
Old 08-23-2009, 06:41 AM   #6
Adger Smith
Liked 880 Times in 311 Posts
Just thought I would post some links to plug reading.
http://www.empirenet.com/pkelley2/sparkplugreading.html
http://www.dragstuff.com/techarticle...ark-plugs.html
http://www.4secondsflat.com/Spark_plug_reading.html
For those that like video:
You might keep in mind the pickup clearance plays a part in the rise time of the signal going to the ignition box. Too much clearance and the pickup will read a short spike from the magnet. To little clearance and it will cause a longer dwell & confuse the signal the box sees at High RPM.
Adger Smith (Former SS)
