Old 03-25-2009, 03:01 PM   #1
Terry Waldron
Question cam degreeing help
I am having a problem degreeing my cam, I degree my cams all the time never had this problem. I can go 2 to 8 degrees advance or retarded and all I get is the same results 109-110 degrees, is something binding somewhere.
Terry Waldron is offline   Reply With Quote
Old 03-25-2009, 03:09 PM   #2
Fred Popov
Default Re: cam degreeing help
Are you sure that your timing wheel is on the crankshaft.... not on the camshaft. You would get the result you described if your timing wheel in on the cam.
Fred Popov is offline   Reply With Quote
Old 03-25-2009, 03:14 PM   #3
Terry Waldron
Question Re: cam degreeing help
Degree wheel is on the crank , have double checked tdc several times to make sure it was right.
Old 03-25-2009, 07:25 PM   #4
Lapeeracing
Send a message via AIM to Lapeeracing
Talking Re: cam degreeing help
That's a good one.All that I can think of may be a sticky needle or plunger on your dial indicator.And make sure that the stem of the indicator is on the same angle as the valve stem.I have had the stem of the indicator ride into the "dish" of the retainer and give you bad readings.Good luck. You will figure it out!
Lapeeracing is offline   Reply With Quote
Old 03-25-2009, 07:46 PM   #5
Terry Waldron
I have the heads off and got the indicator reading off the edge of lifter.
Old 03-25-2009, 08:36 PM   #6
njk53
Check your dial indicator. I had problems with the one I got with my Comp Cams Degree Wheel kit.
Nelson Kowal
Stock 345
Old 03-26-2009, 05:18 AM   #7
RJ
I would also check to the opening and closing spec @.050", always afraid of asymmetrical lobes skewing the numbers.
RJ is offline   Reply With Quote
Old 03-26-2009, 03:10 PM   #8
Terry Waldron
Angry Re: cam degreeing help
Dial Ind. is good, tried different lifters, I am wondering if it is my timing chain setup, I am using the cloyes hex adjust setup. Anybody had a problem with them.
Terry Waldron 5619 K/S
Old 03-26-2009, 07:57 PM   #9
partsbob67
Liked 79 Times in 11 Posts
not implying anything, but is the math right? made the mistake once of subtracting the 2 numbers instead of adding them and dividing by 2.
bob beals 7244
partsbob67 is offline   Reply With Quote
Old 03-26-2009, 08:32 PM   #10
John Dinkel
Liked 263 Times in 68 Posts
Make sure that you take all of the stretch out of the chain.
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
