Old 03-18-2009, 09:16 PM   #1
dartman
dartman's Avatar
Liked 68 Times in 41 Posts
Default Cast 340 Crank
Can you internally balance a 340 cast crank?, they did have weights on the torque converter.
1231 FS/D Drag Pak
1231 E/SA 71 Demon
Kelly MacKay
dartman is offline   Reply With Quote
Old 03-19-2009, 10:19 AM   #2
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Cast 340 Crank
Of course. It's done all the time with externally balanced 360 cast cranks, including mine. Any lighter than OEM weight rods & pistons being used will just reduce the amount of mallory metal, or whatever, that is needed to do the internal balancing.
The OEM 340 cast crank engines also had that special damper/balancer that had "For 340 cast crank only" cast right into the counterweight.
LOCOMOTION Racing
