Old 03-18-2009, 07:35 PM   #1
Denny Steward
Denny Steward's Avatar
Liked 131 Times in 24 Posts
Thumbs up Spring garage sale
1- 20 new #276 Accel Spark Plugs $20.00
2- 1 new Innovate Motorsports LC-1 O2 sensor kit $125.00
3- 2-new 1003 Fel Pro SBC headgaskets $50.00
4- 1 used 39 1/4 inch Alum driveshaft 1350 joints $100.00
5- 1 used set of 426 Hemi Super Stock Heads by MacDowell Racing Heads with matching Hogen Sheetmetal Manifold fresh valve job $5000.00
6- 1-set of M/T 12.2X31.25 X15W slicks 2 runs $400.00
7- 1 used set of steel Koni coilover shocks with 130 lb. springs $150.00
8- 1 used MSD #8770 retard box $25.00
9- 1 used MSD # 8670 RPM selecter $25.00
10- 1 new set Afco front shocks for early Camaro double adjustable $500.00
11- 1 used Demon 650 carb $250.00
12- 2 used Holley 780 carbs $250.00 ea.
13- 1 used Turbo 400 transmission rev. pattern lightened 266 low gear with deep pan FRESH $1800.00
14- 1 used Dynamic 7 inch converter for Super Stock 904 trans $750.00
15- 1 used black Turbo Start battery charger 16 volt $100.00
Call Denny (717) 676-3349 or after 4/3/09 you can also call Brian (407) 474-0898
All parts can be delivered to Cecil Ga. points race, Atlanta National event, or to the Ihra race at Rockingham NC
Denny Steward is offline   Reply With Quote
