Old 03-17-2009, 10:15 AM   #1
SCOTT SST2871
Default Use a proportioning valve or not?
I have a 71 pontiac ventura with the chrysler style alum. Master cylinder..until this week it had 4 wheel drum brakes and the stock dist block..i just installed the stock style front disc brakes on it and plan on putting rear discs on it this summer.would you run the dist.block that came on it or no prop.valve at all.i do drive the finish line aggresively!!
Scott fifield
SCOTT SST2871 is offline   Reply With Quote
