Old 03-16-2009, 09:16 PM   #1
71plymouth
71plymouth's Avatar
Default data logger
can you run a data logger in either Ihra or nhra stock eliminator?
71plymouth is offline   Reply With Quote
Old 03-16-2009, 09:20 PM   #2
FED 387
Liked 333 Times in 180 Posts
Exclamation Re: data logger
NHRA data recorder permitted--per page 112, 2009 NHRA rule book--- Comp 387
Old 03-16-2009, 09:22 PM   #3
71plymouth
71plymouth's Avatar
Default Re: data logger
so would a racepak v300 work? and thanks for the help!
Old 03-16-2009, 09:45 PM   #4
455
I use one and like it a lot, along with their guages that include digital read-out. Their reports for the data are also easy to understand/see on a laptop. It takes a little bit of time initially to get everything working. Overall I would say their instructions are very good. Technical support is excellent. It has been extremely reliable, no problems.
455 is offline   Reply With Quote
Old 03-17-2009, 05:13 PM   #5
CycloneFE
CycloneFE's Avatar
Liked 2 Times in 2 Posts
Does anyone have any experience with the new Autometer system?
Old 03-17-2009, 08:42 PM   #6
Chris DeGidio
Chris DeGidio's Avatar
The new Racepak Sportsman version is $699 and it looks real nice.No wires from the car to PC,uses a SD card like in your digital camera.
Nautilus Racing
Chris DeGidio is offline   Reply With Quote
Old 03-18-2009, 05:59 PM   #7
71plymouth
71plymouth's Avatar
what sensors are the most important on a stock eliminator car? i know that they come with a lot of sensors like boost, driveshaft speed...etc.
Old 03-20-2009, 07:08 PM   #8
455
Would not say these are most important, but they are some of what I monitor and track, in no special order:
o Engine RPM;
o Battery voltage;
o Carb Fuel Pressure;
o Fuel Pump Pressure;
o Oil Pressure;
o Oil temp;
o Trans temp;
o Water temp;
o Trans pressure;
Would suggest if possible that you view the system you are interested in, at a race, see if someone who has one will let you look at the data you are thinking about monitoring.
Also, identification of your data needs is a first step, which can be for several purposes, such as history( change in oil pressure can indicate a developing problem) or optimizing performance ( fuel pressure could be low at launch). Another example is very accurate RPM data can show engine issues. Areas you are doing R & D, and need to monitor what effect changes have. For me I have learned a lot.
Hope this helps.
Old 03-21-2009, 10:27 AM   #9
71plymouth
71plymouth's Avatar
Thanks for the help!
