Old 03-16-2009, 06:47 PM   #1
bkeesee
Default Garage Sale
Cleaning out the garage in preparation to move and I'm tired of lugging some of this stuff around so it's got to go.
-Bare block- Large journal mains w/ steel 4 bolt caps, filled to bottom of water pump holes, 3.935 bore(+.060 283 or 307) one cylinder dinged up from dropped valve so might need 1 sleeve to repair- no cracks --Make an offer
- 2 sbc 327 steel cranks{3.25 stroke}, one is large journal main, small journal rod both standard the other
one is a small journal on mains and rods and has been turned either .020 or .030( I can't remember)
$150.00 for the first one $80.00 for the second
- 2 SBC solid roller camshafts $150.00 each
#1-Lunati Grind #RRA 326/336 Intake .703 / 285@.050 Exhaust .652 / 296@.050 w/ 1.5 rocker 109 L/C
#2-Lunati part #50141-108 grind # RRA-284-285, Intake LOBE LIFT .468 /284@.050 Exhaust LOBE LIFT
.420 / 285@.050 108 L/C
New (old stock) set of Speed Pro piston rings 4.035 bore, .043 top,1/16 2nd, 3/16 oil - part # N9785-035
$50.00
Hays 168 tooth 40# steel billet flywheel(used) $100.00
Will consider all offers- Prices don't include shipping
Possibility of doing some trading for a Holley Pro Dominator or Victor Ram tunnel ram intake for a SBC
Can deliver to Farmington Dragway or anywhere in Winston-Salem, NC area.
bkeesee is offline   Reply With Quote
