Liked 19 Times in 7 Posts
So my question is...why are you not allowed to run a 350 turbo trans in stock in a small block 68 Camaro. I bought a 295hp stocker motor on this board, drove 7 hours to pick it up to be dissapointed that I can't run it because of the trans rule. My fauly I know, should have read in between the cracks that are in between the cracks in the rule book. So now do I spend $2000 on a new powerglide trans/converter to run the motor or freshen my 330hp crate for half that money and run it again? Heres my beef....check out the links.
http://www.kitcarusa.com/kb.php?aid=108 - scroll down untill you see 350THM http://www.automobilebestbuys.com/an...s.php?RID=1574 http://www.experiencefestival.com/a/...350/id/5547454 Theres alot more crazy combo's in Stock than a 3 speed behined a 295hp 350...but we won't even start a new 72 page thread. ![]()
Tony Valerio 1968 Camaro 1700 IHRA H/CM 1701 NHRA SS/?A |
Fot the second link. Seller comments.
This Baby is a THM350 (Turbo-Hydramatics Only available on the SS396 Camaro)! Stick a 396 in it.
Next time wave all of your fingers at me. |
Crate Camaro,If you are going to run all IHRA I would freshen the Crate Motor,It is alot easier to make run under the Index,On the flip side the 295/350,with a glide is a very consistent combo,but will not win any heads-up races. I have run this combo for years,wasnt that bad until all the Technology came around for the three speeds now it is a horrible combo,NHRA will not allow a three speed in a small block 67-68 camaro because chevy didnt put a three speed behind the small block until 69.You are allowed to run a 295 hp Motor in a 69 or 70 Camaro @ the same hp rating with a three speed.GOOD LUCK.
#4 | |
Liked 8 Times in 7 Posts
besides, i'me pretty sure th350's didn't enter the scene until 69...in anything. |
#5 | |
Liked 282 Times in 103 Posts
Don't be so sure about not being able to win any heads up races. If NHRA allowed you to run a three speed,how much do you think you would pick up? See you at Indy. |
350's showed up late 68... had large journal rods with 11/32 bolts. still have some at the shop.Opps... dating myself
Bub Whitaker |
Liked 166 Times in 71 Posts
True, big blocks would have had the th400, but with the rules the way they are, th350's can be used.
Daryl,
I would be able to pick up .18-.20,ask Gary Russell if you dont believe me he has done it for a test,Freddy Burris and I Pitted together for years and he ran a glide at points meets and a 200 MaClay when he needed to go fast and his 200 was always 2 tenths faster. |
Bub,
You are correct about the Late 68's having a th350,but getting NHRA to acknowlede it is impossible,they allow super stock cars with glides a 3 speed but the glide doesn't slow them down as bad as they do in a low hp. stocker,we need gear. |
