I have a 2 channel Autometer playback tach that I use to record every pass I make to make sure the clutch tuning is in line. I just changed a rear gear and when running in the new gear this past weekend I had the magnets come off in the driveway. It appears that the JB weld de-bonded from the U-joint cap. Is there a better or an improved method to attach the two magnets to the driveshaft U-joint caps besides the JB weld that Autometer suggests?
Thanks Dave Oopps I just realized I put this in the wrong section sorry.. Last edited by Dave Toce; 03-11-2009 at 08:15 PM. |
Liked 10,763 Times in 2,237 Posts
Mark Williams is the answer.
Liked 520 Times in 132 Posts
Collar from Williams
Liked 223 Times in 73 Posts
Autometer also has collars a couple differant rear end sizes and a universal one you can machine.
Liked 320 Times in 102 Posts
Hi,
Sometimes there are clearance issues with the collar around the companion flange. As an alternative solution, you can drill the companion flange and insert the magnets with a little epoxy. Worked for us, Bob
