Old 03-10-2009, 05:21 PM   #1
Ray Menard
Ray Menard's Avatar
Default Super Stock/Modified Motor
306 cu. in. Small Block Chev. Former Jim Cowan (Comp. Elim. Champ) Motor. Update by Rick Watters of RWR (formerly Eaton Enterprses). AED Carb (2), Enderle Carb Linkage, Hogan Intake, Bullett Cam, 16 Deg. Alum. Heads, Jesel Timing Belt & Shaft Rockers, Mallory Comp 9000 Front Distributor, MSD Wires, Crank Trigger, ATI Damper, Moroso Custom Alum. Oil Pan, ARP Bolts, etc., etc. Makes 446 lb. ft. Torque @ 8,000 RPM and 728 HP @ 9,400 RPM. Dyno sheet available. Zero runs since dynoed. $26,000+ to duplicate. Asking $15,900 OBO (save $10,000). Pictures available.
Ray Menard
SS/CS (SS/DM & SS/EM)
#7386
Ray Menard is offline   Reply With Quote
